I wonder if there is any one out there that help me solve a problem I'm experiencing with a Linux distro disc.
I have two netbooks each installed with Windows XP Home edition. Both machines are connected via a Netgear DG834 wired router. Internet access and file transfers are working without issue in Windows.
The problem I have is when I boot from a Linux SuSe distro CD. The disc contains backup software which can be used for creating and restoring images of most operating systems.
Linux detects the NIC successfully and I can configure its IP address/Network mask and default gateway (the router IP address). No DNS or Wins servers are configured.
The problem is that it is unable to find the network path of the other machine.
I tried entering the path manually and it still fails to find it.
I know that the network card is properly configured as I am able to ping the router from this "Linux" machine but I can't ping the NIC address of the other netbook.
<edit> I *can* ping the target machine succesfully.
I don't have much *nix experience so bash commands are new to me. I did try to browse the LAN using the following command:
I believe typing "nmblookup -M -- -" should give me a IP list of network master browsers. The name query fails on the broadcast address 192.168.0.255.
Is any able to help me troubleshoot this please?
Cheers,
Rob.
Cheers,
Rob.
