Have an interesting problem to fix, my neighbors 96 VW Polo with a 1 litre engine. Has been parked up for about a year and appears to have seized up
Starter engages cleanly, clutch is free an working, and rocking the car back/forth in gear its clear the crank shaft wont turn. Pulled the plugs out and had a look in each cyl, no liquid in there locking it up, bores look like they still have a film of oil on them, certainly not dry and rusty. Pulled the timing belt cover to make sure it still has a belt, all looks good. Also checked altternator and pulleys were all free so whatever the problem its crank or pistons. All i had handy was engine oil so poured a bit in each cyl and left it to seep in.
I've heard of engines locking up that havent run in 10 or 20 years but not in this short a time. Found lots of things to try from filling with warm diesel oil and filling the cooling system with boiling water to heat it all up. Anybody ever had this before? Or any good tips for freeing it up without having to pull it all apart?
