I have bt broadband at home and use a bt type 2 hub to connect with WiFi to the net. I'm getting infinity installed so the current hub modem WiFi thing will be no longer used. My thoughts are that I have no WiFi in my garage about 100m away from the house. It would be handy to check things on the net while working at the car. Also I have no 3g signal coverage at home or garage.
I have cat 5 cable running from the house to the garage, so can I install the old bt hub thing in the garage and use the cat 5 to send the internet from the house to its WiFi.
If not what do I need. I would eventually like to fit a CCTV camera system to the garage and connect it to the hub in garage with cat 5 and look at the pics from the internet if required.
Cheers des.
Cheers des.
