i read on the forunm [but cant find it now] a company in usa that can shorten the drive shafts for ur . i need the n/s/f to be 5 to 10mm shorter as we have 01e gearbox box . shaft is currently 541mm end to end , is there a shaft around 530mm from another audi with same style fixings [hub nut ect]
may give reco prop a ring. we already have a spacer with a additional wider motorsport inner cv fitted to the o/s f shaft which seems to be fine and correct travel , whats the norm ? when using ur struts and shafts on the o1e
