B5 subframe vs S2 Avant
  • MARKMIDGE
    • Nov 2014
    • 339
    Morning. Have had a look around and can't find difinitive answer to this. Does anyone know if the b5 rear frame is the same as S2 avant, have read that wishbones are slightly different but not sure if I can use b5 subframe with s2 wishbones and uprights. Cheers
  • mcandmar
    • Apr 2004
    • 5118
    I remember somebody used one in a B4, the only difference i am aware of is the rear tie rods are longer on a B5 so the mounting points on the subframe are closer together. i.e. you will have to use B5 tie rods with it.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • MARKMIDGE
      • Nov 2014
      • 339
      Ok, thats good news, thanks for that.
