Rear diff oil leak s2 3b
  • Backe77
    • Jun 2017
    • 20
    I have a small oil leak on my s2 3b, oil seams to be coming for where the dif lock arm connects to rear diff, I’m hoping there’s a seal in there that needs changing,appreciate any advise , and maybe where I can locate parts needed
  • tekstil
    • Jun 2011
    • 104
    There is no seal there, you probably have actuator arm rubber boot leaking. Part no: 017525075A
    Checked Audi Tradition shop and seems to be available.
    • Backe77
      • Jun 2017
      • 20
      That great , I’ll get one ordered,hopefully the sites working again , do you know if it’s possible to change without dropping dif
      • tekstil
        • Jun 2011
        • 104
        No need to drop anything, plenty of room around there. Just release vacuum actuator rod from the arm, remove clamp and off it comes.
        • LSG
          • May 2010
          • 897
          Be careful not to bust anything. It's in the elements a little and doesn't get a lot of work so maybe seized up. I had to mend one for a good friend . He tried to find a replacement unit but couldn't. I believe the rubber boot is about £50 quid as I also require one for my aby . Good luck kind regards Lynn
