Dyno results with EFR6758
  • sjw185
    • 1175
    Here are the results from a dyno run last month with the 3b Track car.
    Running well and sounds mental
  • PRY4SNO
    • 767
    By that curve, looks like it takes right off at 3k rpm. Must be quite the shove. How does it feel to drive on the street and track?
    2013 Touareg TDI /// #farmenwagen
    • sjw185
      • 1175
      Stripped out with LSD and federal 595 tyres is a good combination, was recently at track with damp conditions the grip and performance was stunning the limiting factor is my driving, can't wait to drive it on a dry track next year
      • rxl
        • 1913
        My dyno run with the same turbo
        Gesendet von meinem EML-L29 mit Tapatalk
        • sjw185
          • 1175
          Originally posted by rxl
          My dyno run with the same turbo [/IMG]
          Nice result, How you getting on with yours not see a update on your thread for a while
          • rxl
            • 1913
            gave up with mine.. seems something is broken allways and i was to tired to put money in that black hole... bought something newer and kinda glad my decision.
            • sjw185
              • 1175
              Yea the S2 can be tough mistress to live with, I spend more time working on them than driving them for sure
              • larsaskogstad
                • May 2020
                • 674
                • Country: Norway
                Sorry to bump up an old thread, but are you both still using the efr 6758? How does it feel to drive compared to something like a kkk / rs2 setup?
                Does it feel like the torque is coming on strong early or does it need a little rev before its happy?
                Got a built engine but stock cams atm, no 7a since I want the driveability for a street car, considering what to get.
                I am looking at everything from a rs2 hybrid setup to efr 6758, 7163 or gtx2867r gen2 , any suggestion or feedback?
                https://www.s2forum.com/forum/member...-3b-1991-coupe
                • rxl
                  • 1913
                  efr turbo makes the car feel like modern car. almoast no lag and good powerband. i used also stock cams as had no need for some other cams. efr turbos got realy expensive and getting one is kinda not that easy. for my new engine im going for hybrid rs2 turbo now.
