Hi guys. AQC 20v, nothing out of the ordinary, pull the bonnet pull but has no resistance to it and no pleasing bonnet pop. I can hear the cable when i pull the bonnet pull, its like as if the cable has come of the bonnet catch. anyway how do you pop the bonnet if this has happened. Thanks if its not one thing its another
Check the pull handle bolts are tight. Otherwise cable has stretched slightly not pulling the two release leavers properly. You can release them with a long thin screwdriver to the side of the lights. Before you do tbat, get someone to pull the handle whilst you press down on the bonnet.
