Ignition Switch Replacement guide?
  • Ignition Switch Replacement guide?
    Hi, has anyone come across a guide on how to replace the switch. I assume it’s the same on an RS2, S2, etc.
    Cluster out, plug off, loosen 2 small flatblade screws besides the switch and remove the switch.
    1989 Audi 80 Quattro
      Ok great, thanks.
        If you are talking about the ignition switch, not ignition lock. The lock can also fail, so that it does not turn the switch anymore.
