Location of the outside ambient temperature sensor
  • 4WDrifter
    • Nov 2012
    • 1251
    Where is this located? It previously seemed to work fine and gave a pretty accurate reading of the outside temperature but lately it’s all over the place up to 45’c then E. I think it might be dislodged from where it should be and its reading the temp in the engine bay or somewhere pretty hot.
    1996 S2 ABY Coupe silver
    2003 S3 8L dolphin grey
    2014 RS4 B8 prism silver
  • Ian Simmonds
    • Jun 2005
    • 2858
    Under the bonnet, in the heater box air track ISTR.
    when you stand between the headlights, go top right area, it’s under the black trim below the windscreen.
    93 MTMS2 Avant
    • david1980
      • May 2014
      • 1028
      I thought it was behind the bumper on right hand side?
      • Ian Simmonds
        • Jun 2005
        • 2858
        Hmmm, just checked this.
        Might be I’m thinking of the air con recirculation motor (page 9). Sorry.
        93 MTMS2 Avant
        • 4WDrifter
          • Nov 2012
          • 1251
          Thanks guys.
          • johne
            • Apr 2007
            • 1406
            It is behind the bumper. On my car it's on the LHS ahead of the radiators.
            There is a thermal sensor, actually a thermal switch on cars without climate control, in the heater inlet tract on cars with AC. It's there to shut off the AC compressor at temperatures below 5 degrees C to prevent the evaporator matrix inside from freezing up and blocking all air from coming into the car.
            • 4WDrifter
              • Nov 2012
              • 1251
              My car has A/C so I’ll look for this one too.
