Hi all, Just wondering whether anyone might have any advice at all. Basically my b4 audi 80 1.9 tdi has always started first turn of the key as soon as the starter cranks. Recently it cranked over ever so slightly longer then started and did this for a few days, and by the end of the week it would need repeated prolonged cranking say 8 times or so with smoke coming out of the exhaust before it would eventually start. Once started it will run fine and can be restarted like normal, but if left for a few hours it's back to the same story. The garage don't think air is getting into the fuel lines and have changed a couple of sensors and no change, and have now told me they are going to wire in a manual glow plug control and say it starts fine like this (I normally never see the auto glow plug light come on at all until it starts getting much colder).
Other things potentially to note (or not haha) is a couple of weeks before this I started hearing more turbo/exhaust noise and it has snapped an exhaust manifold stud but apparently this shouldn't affect starting. 2 years ago I did also have a fuel leak from the fuel pump and the rubber gasket was replaced and the pump pulses a bit on idle, which I was told by a pump expert is just how it is. In case any of this is relevant.
