Head scrstcher for techheads Audi A8 W12
  • CHEN
    • 329
    I know its not an S2, but there are some clever people on here and I'm hoping one of you can help. We have a 54 plate A8 W12 here and I can not get the ignition lights to come up at all. I have the key. It was in a flood and a few electrical boxes were knackered I have replaced these. The problem is with no ignition lights there is no VAG COM and with no VAG COM I'm working blind.
    Ideas Anyone?
  • topsparky
    • Oct 2005
    • 2014
    have you checked all the relays mate
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
    • gib
      • Jul 2006
      • 42
      • Home: Wales Current: United Kingdom
      It most likely in deep sleep.
        Is the battery still working ?
        Have you checked fuses ?
        • CHEN
          • 329
          Have checked all fuses and relays most of which have power. The battery is fine. I don't think it is in sleep mode because VAG COM should be able to de-activate it
          • madpugger
            • Sep 2007
            • 1901
            I had a similar problem with the S3... which turned out to be one of the 50 or 100 Amp fuses on top of the battery... I checked them three times and it didnt look gone, but when they were bridged all was good! So a new one and hey presto! They are held in place with 8 or 10mm nuts iirc.
            Le Mans 2012
            Nurburgring 700
            1995 S2 Avant
            • Dan_s2_coupe
              • Aug 2006
              • 482
              yeah sounds like u have lost a main live.
              What are the earth points like at the bottom of the a pillers like
              could also be a CAN fault from power suppy control unit if there is a wet CAN connection will play up real bad
              • shark_90
                • 1475
                I'd love to come and have a tinker around with this one.. just my cup of tea. Shame I'm so far away.
                1994 Audi S2 Avant - in pieces
                2006 Skoda Octavia vRS 2.0TFSi - goes fast
                1985 Audi 90 quattro - is wet
                Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
                • CHEN
                  • 329
                  Thats what I thought at first, now its beginning to do my head in, The main fuses are fine and everything that should be getting power seems to be getting it I'm wondering if the ignition switch has shorted because it just seems like it doesnt recognise the key, even though it was well above the flood level
                  • urquattro-island
                    • Mar 2006
                    • 1915
                    • Home: Norway Current: Iceland
                    you
                    have changed all that was in the flood?? how high did it reach??
                    You can wake the ecu up with, holding the foot on the brake pedal, while reading with the vas 5051 or 5052, this wakes the system up, or flash the highbeam.
                    japanischer industriabfall nein danke!!
                    www.rackeltrim.se Icelandic Division
                    • Dan_s2_coupe
                      • Aug 2006
                      • 482
                      what control units are under the carpets
                      • urquattro-island
                        • Mar 2006
                        • 1915
                        well
                        you have the control unit for the transmission, useally on the passenger side, and the electronics box on the driver side.
