how much side to side or up down pulling on shaft is acceptable on a new turbo or should there be none?
turbo shaft play?
Originally posted by AUDI COUPE 20V View Poston my car when i pull away 1 st 2nd nd on boost sounds like a scrathing or cathing sound like the blades is catching the housing , i can feel shaft play up and down or side to side , on turbo not tried it longitudanally though
I've had this for about 1500 miles now and not noticed any loss of performance (noise seems to be dying down a bit too).
When did the noise start for you? Had you had any work done just previous?sigpic
It shouldn't make that noise... if its getting quieter it is probably wearing away which it shouldn't do either..
Max side play on an oil journal turbo (K26) is .55mm. end float is .2mm i would imagine its the same for a K24.
But best to check it out you don't want a blade to snap off and pass through the engine, the cold side is easy to check with a mirror and torch.
Good luck.
the turbo shall NOT have play in/out( if so, look for oil leak by the inlet/ cooler)
the play Up/ down, shall NOT have the blades in the walls... if so the turbo are gone.
tips: by a new one with 360 bearing, and not with 270 or BB bearing..... the trucks and lorrys does have 360 bearing.........
bro! the safe shaft play is "safe" when the wheel blades doesn't touch the housing... too much play will cause damage to the blades, a loss or total loss of boost pressure, a constant damage to the bearings that will end in a much worse damage including the engine.
Mery christmas to you and all the forum members!!!!!!!!!!!!!!!!!!!!!!- Looking for a S2
