problem with all vdo gauge lightiing
  • ryster
    • Sep 2007
    • 224
    hi please can someone help me with this problem, I was fitting my boost gauge in centre air vent and decided to take the power for gauge light off the back of the oil temp vdo gauge.there was a slight smell and now none off the instrumental ligthing works at all.
    I ve checked all connector and fuses i will check fuses again but does any one know off any other problems that may of ocurred . Otherwise its a trip to the nearest
    auto electrician cheers
  • Jas11n
    • 5067
    Is it just the aux gauge lighting? There is a booster relay for aux gauge and dash lighting behind the aux gauges. Maybe you disturbed it, or a short has blown it?
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • ryster
      • Sep 2007
      • 224
      know its all off then includeding speedo etc
      • Nuvo
        • Nov 2003
        • 3825
        You may find that the glove compartment switch/bulb wiring is short circuit. Try disconnecting it and replacing the fuse for the instrument bulbs. The fuse can be found in the main fuse box in the engine bay.
        I'm guessing its a yellow 5A on and the ref is S14, I can't honestly remember for sure.
        • ryster
          • Sep 2007
          • 224
          cheers mate! ill try anything.
