How much Hp can a stock Drivetrain Handle
  • mocas
    • Jan 2007
    • 49
    • Home: Madeira Current: Canada
    OK i currently own a 1990 audi 90 coupe quattro with a 3B swap am planning to build up the motor this summer i was just wondering how much Torque and Whp can a stock drivetrain hold before it blows up? My goal is around 400-450 WHP.
    Thank you
    There are two choices in life-Take it or leave it !
  • T2Andy
    • 1903
    Over 500hp if you dont keep dropping the clutch ,the diff is probably\clutch would
    go first ,but you would uprate the clutch anyway.
    • prosty
      • Jun 2005
      • 1114
      The clutch (if you get a sachs) will never fail you. The diff can break after a while, the drive shafts are the things to worry about, about 150 starts, then my diff broke.. So I can vouch for audis power in making drivetrains. The shafts can brake if your drivetrain is sloppy, or if you don't tighten it before launching.
      2004 9-5 aero
      2009 Subaru Legacy Diesel
      1994 Toyota Supra Eurospec 6-spd LHD
      3-4 Audis in parts
      • mocas
        • Jan 2007
        • 49
        Thank you guys for the info, definately will get an upgraded clutch i was just curious if the stock drivetrain could handle 500hp if its in good running order that is.
        • quattronutter
          • Jan 2005
          • 690
          paint some white lines along the length of the driveshafts,this way you can see if they are twisting,i have seen them as far as 180 degrees twisted on some works cars
