Avant Upgrades
  • Azman
    • Sep 2005
    • 3205
    Avant Upgrades
    Hi guys,
    Right some advice please from those that have them.....
    It is an ABY and i am used to the 3B so give us a clue on
    What to do to the avant I am shortly to get my hands on
    Easy one.....
    1. 996 calipers on the front (got em so no probs)
    Add to the list, anything I can salvage off the coupe would be good..
    Everything else is up for grabs guys, I will post it one here first and then it will go on the bay if there is no response.
    Please don't bombard me with PM's as I am going to wait till I have the avant sorted before I send the blue one to its resting place, but for those who want to come and get bits I will have a stripping day so you can come and help me get the bits off and collect them at the same time......
    Hmmmm Forum Meet???
    Az
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
    Az,
    I'll do you a bargain basement deal on some lovely homely fries on that Avant if you supply the rear diff from that 3B of yours. No ultimate urgency here - just need one for a Torsen transplant.
    Hopefully thats my spoke in first.
    As for other upgrades on the Avant, I'd say the RS2 ARBs and dampers will be great - if not cheap of course. The brakes you know about already... 996 monos up front and the full-fat 300mm 8E0 approach works at the rear - again not cheap - sorry.
    RS2 Airbox and IC are bolt on easy gains also...
    Cheers,
    Paul
    • MidnightBlueS2
      • Jul 2005
      • 1653
      • Home: United States Current: Belgium
      Everything I did to mine.
      Midnight Blue S2 - SOLD - 1993 S2 Avant
      • Azman
        • Sep 2005
        • 3205
        already got the carbon trim, Rs2 Farb, Samco coolant hoses, 996 Calipers (323 discs),
        Bigger cooler,
        Do the 996's fit behind stock 16" wheels with 323 discs???
        Dark Grey Avant
        RS2 FARB
        • TEKNOPUG
          • 125
          Bigger cooler,
          I don't think so, no (from reading numerous previous posts but I stand to be corrected)
          1990 Peugeot 205 1.9 Turbo 192bhp - 190lbs/ft
          1996 Vauxhall Omega 3.0V6 Ex-Plod - cop motor, cop shocks, cop brakes, cop LSD. Cheap, tatty and comically sideways!
          • denniselbows
            • 740
            Bigger cooler,
            i am sure the movit brakes are 323 discs and they fit behind 16" wheels. shaun5 would know for sure
            never set your expectations to high that way you are never disapointed
            • Smith_S2
              • Feb 2007
              • 634
              i though that 323's did not fit behind 16" wheels?
              • shaun5
                • 1610
                I have got mov-it brakes with 323x32mm discs and my avus 16" rims fit over them albeit not by a lot. Early type wheels u need a spacer
                  I say you need a spacer on 16" Avus with the 323mm disc and 996 monos with RS2 carriers - had a trial fit myself to be certain. There's plenty other threads on the subject... You really need bigger rims or to reduce disc diameter to something like 307-308mm and machine the carriers down a tad.
                  PAul
                  • shaun5
                    • 1610
                    I have got the complete set up baught from QST in 2001 fitted to my car. Im not saying my calipers are 996 ones. I dont know what carriers either . All i know is they fit and work extremely well
                    • BRY
                      • 3755
                      I don't know of any problem with a Seat Bracket machined to suit the 314mm disc under a 16" Avus wheel.
                      The 323mm will just fit, but it leaves no room for any debris between the caliper and the wheel. A spacer would work, if you want to use one. On an avant it would help with the stance of the car as the rear has a slightly wider track.
                      • shaun5
                        • 1610
                        Yeah you can only just get a piece of paper between the wheel and caliper but like i said, mine have been on for 7 years with no debris problems
                        • Azman
                          • Sep 2005
                          • 3205
                          Just thinking as if I can get them behind no problems then the wheels on the car will do me for a while, until I manage to get my hands on some porsche reps or something!!
                          Dark Grey Avant
                          RS2 FARB
                          • Azman
                            • Sep 2005
                            • 3205
                            Well the easy way to find out I guess is to take the front wheel off the coupe and try to drop a 16" one off the avant onto the setup!! That will be the teller won't it...
                            Best suspension upgrade still Koni's and stock springs or H&R??
                            Dark Grey Avant
                            RS2 FARB
                              323 an 16" don't mix, ask Alistair C http://www.slybadger.com/cars/s2/brakedetail-new.htm
