F1 turbo era
  • gnutz2
    • Aug 2006
    • 928
    F1 turbo era
    Take a look at these turbo F1 engines, The renault engine uses the DPV system created by jean pierre (french engineer), a form of antilag which uses variable nozzles to control the air into the compressor instead of a simple throttle plate that most of the other teams use.
    IIRC the throttle is located before the compressor and instead of a BOV (blow off valve), a POV (pop off valve) is used which vents any pressure over your desired boost pressure to atmosphere. With all airflow blocked to the compresssor blocked between gear changes the turbine/compressor shaft speed stays in the maximum efficiency area on your compressor map which gives instant throttle response. Apparently the renault drivers did`nt know what turbo lag was
    Was thinking of trying this on my car as a little project.
    The ONLY S2 Golf!
    10.42@138mph
  • Puglife
    • Jun 2006
    • 731
    For university we got a free tour of the donington F1 museum.... I'm not an F1 fan but the technology even back in the day was mental...
    I'm sure they ran 3-4bar of boost as well?
    Jay - pug_life85@hotmail.com
    1986 Audi UR quattro - WORK IN PROGRESS
    1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
    • Acidburn
      • 13459
      Well if going by what you've done so far it should be of a high standard, it will be interesting to see something new being done.
      • gnutz2
        • Aug 2006
        • 928
        Just been reading, the alfa romeo inline 1498cc 4 cyl made 885bhp at 10,500rpm and up to 1300bhp in qualifying with no fuel restrictions
        The ONLY S2 Golf!
        10.42@138mph
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          They had variable boost control from the cockpit with a 4bar limit in the race and 5.5bar for qualifying....that's 1300bhp from a 1500cc 4cyl engine
          Cheers n
          Si
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
          • Rusty
            • 18953
            I think that it was either Renault or BMW that had a 1500bhp engine in qualifying trim.
            • GT500
              • Jun 2006
              • 2181
              I remember the BMW in the Brabham, the BMW engineers looked at water injection to help with the detonation at high boost, then realised why inject a substense that dosent burn? no shiit sherlock!
              They pulled some fuel data from the war used for the aircraft of the time. Mixed similar and hey presto reliable 1500 bhp!
              Rob..
              87 UR 20v ABY
              97 S6 Avant
              • BrianSmith_S2
                • Jun 2005
                • 1342
                • Home: Northern Ireland Current: British Antarctic Territory
                Wasnt the BMW engine block the one that came from a humble road car begining ( a road car that had done 100K). I seem to remember it was left to age (rust) outside the BMW engine plant to stress relieve the structure. apparantly urininating on the block helped the process
                • BrianSmith_S2
                  • Jun 2005
                  • 1342
                  Well the Focke Wolf 190D with the BMW engine had a variant that used laughing gas at high altitude to boost hp. those crafty germans
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Reminds me of a 6R4 rallycross car my dads friend had. He reckons the boost knob on the dash could dial in anything from a season to 20 minutes
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                    • lagomike
                      • Nov 2006
                      • 112
                      Yup the M10 engine, you watched that chris barrie speed machines programme by the sounds thats where i heard it
                      • Keeper of The Kitten
                        • Dec 2003
                        • 2317
                        Well known story!!! It's still a rumour but most likely to be true - the older blocks have tighter grain structure, and the theory also follows that the engine has had all the stresses beaten out of it already, so it's done all the "settling down" that it's ever likely to do.
                        There used to be adverts in the American magazines for mail-order engines that featured "seasoned" blocks - the same idea applied as per the BMW blocks for F1, just a little larger than 1500cc...
                        Martin Cutting
                        • BrianSmith_S2
                          • Jun 2005
                          • 1342
                          Has anyone tried this out on an S2 block, could be worthwhile project
                          • BrianSmith_S2
                            • Jun 2005
                            • 1342
                            Nice rolling road result.
                            My S2 has it beat upto 7200 rpm
                            • Rusty
                              • 18953
                              But your S2 weighs nearly 2 tons whereas an F1 car weighs 1/2 faff all! (or about 500kg!)
