i fitted the xenon lights to my s2 today they are from the cabrio model using the projectors, they work perfectly but there is now a bulb sign on the autocheck system once the low beam is switched i think someone has had this problem before??? has any one got any suggestions to remedy this problem?? I think someone has modded the relay on the autocheck system???? Any help would be appreciated. If you fitted aftermarket hid kits would you get the same problem???
fitted xenon lights!!
