Main beam playing up.
  • rs2315
    • Jun 2006
    • 867
    Main beam stalk starting to play up.
    Main beam will not come on, unless stalk is FIRMLY pushed forward, and when pulling stalk towards me to flash lights, I'm getting nothing at all.
    Is this a well known problem on a 14 year old RS2?
    Any advice on what to do to sort it would be appreciated.
    Cheers.
    rs2315.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    not a weeeell known,but has happened before.
    take the stalk off by removing the top plastic cover,and take the plug out.Then use some good connector cleaner,one that doesnt have any oil in(yuck) and spray everything there.It might do the trick!
    it did on mine and hasnt have a problem since
    • shark_90
      • 1475
      My 80 TDi used to do this.. I have to admit that I sold it before I fixed it!
      1994 Audi S2 Avant - in pieces
      2006 Skoda Octavia vRS 2.0TFSi - goes fast
      1985 Audi 90 quattro - is wet
      Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
      • merlin's S4
        • Jan 2005
        • 1539
        I think it's fairly common for the switches to fail. I just had to get another one for my S4. There are usually some on ebay and the same part can be found on several different Audis so shouldn't be too hard to find.
        • GT500
          • Jun 2006
          • 2181
          As Vasilis says, It will just need a clean. Dust build up.
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • rs2315
            • Jun 2006
            • 867
            Thanks for that lads.
            I've taken top cover off, and removed bloody big plug.
            Would of been easier to shift with lower cover removed, but looks like steering wheel needs to be removed???
            Can anyone give me a product name for cleaning connectors, something I can pick up from Halfords. Is it just a case of spraying liberally over connectors? What about spraying into plug?
            Thanks for the help so far.
            rs2315.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              sprey both the plug and the connector.
              I had once bought a nice sprey contact cleaner which was good cause it quickly evaported.Then i found one that had oil in and i dont recommend it.I bet if you look at halfords or the net,you will find something.Anything without any oil in will be fine.
              • rs2315
                • Jun 2006
                • 867
                Thanks Vas, I'll get down to Halfords and see what I can get.
                rs2315.
                • Matt_D
                  • Dec 2004
                  • 515
                  IPA from Maplin will do it, funnily enough my main beam is doing this too
                  '95 ABY Avant - Sold
                  '98 B5 S4 -MRC400+ = 464ps 741nm
                  • rs2315
                    • Jun 2006
                    • 867
                    rs2315.
                    Well I gave it a good spray, put it all back together, no joy.
                    I reckon the fault lies in the stalk.
                    A dodgy switch has been mentioned, any other suggestions chaps??
                    Cheers.
                    rs2315.
                    • stiglet
                      • Aug 2007
                      • 1264
                      My old 16v did this. you need to take the stalk assembly OFF the steering column and then take it apart and just clean up all the contacts.
                      To do this, you need to take off the steering wheel, then take off the stalk assembly with the 2 plastic halves of the cover by undoing the big jubilee clip style screw thingy inside the cover. You can get to it by putting a screwdriver in the big hole underneath. Very easy takes about 10 mins.
                      • GT500
                        • Jun 2006
                        • 2181
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                        • rs2315
                          • Jun 2006
                          • 867
                          Thanks fellas, I'm gonner see it through to the bitter end.
                          rs2315.
                          • S2Coupe_Nic
                            • Jan 2008
                            • 260
                            Failing that, 'laser avant s2' aka Al is braking an S2, do they have the same stalks? maybe he has one?!?
                            • rs2315
                              • Jun 2006
                              • 867
                              Ta for that.
                              rs2315.
