I have removed the heatshielding under the turbo/airbox of my RS2 as it was looking pretty shabby. Does anyone have a part number for the two pieces or know of any also would it unwise to leave them off completely. Any thoughts and advice are appreciated.
Simon
You might leave the S2 fold every so often - but you'll always come back!
I've used kitchen foil in the past so if you're stuck then that might be a quick fix until you can get something sorted.
No idea on part numbers but if you get stuck then use the originals as a template and make sone up out of some sheet metal from a local supplier, shouldn't be too difficult.
895 804 161 is the upper one
895 804 162 is the lower one.
Sorry, my folders containing all my receipts are out of reach for me at the minute (filing cabinet in the loft) but from memory they were about £30 each inc VAT + delivery from vagparts, which isn't far off what the FA is telling at £36 each.
HTH's
Jase..
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
