what's the best way to remove casting marks?
  • Josh-stateside
    • 741
    I've got a few cast iron parts that i want to make smooth. I've done it a few ways. I'll now looking into allternative ideas.
    File, Dremel, die grinder, Extrude-hone(tm)?
    • Keeper of The Kitten
      • Dec 2003
      • 2317
      Extrude-Hone! There's a blast from the past, remember reading about that about two decades ago and this is the first time I've seen anyone else mention it!
      I think the honest answer is patience and a die grinder.
      Martin Cutting
      • Heat Seeking Missile
        • Jul 2007
        • 658
        Turn or mill it, depending on what machinery and equipment you have access to.
        Mark
        '93 Brilliant Blue Audi S2 Avant - Broken again.
        '98 Tahiti Blue Rover 216SE Coupe
        '96 Arktiksilber Metallic BMW 525td (E34)
        '01 Dark Green Jeep Grand Cherokee 3.1LTD
        '97 Polar White Vauxhall Vectra 2.0Di LS
        '96 Alpine White Peugeot 306 XLDt
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          Die grinder (or angle grinder with a flexi disc) --> shot blasting --> powder coating
          Cheers n
          Si
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
          • Graham
            • 1622
            Rotary burrs in a die grinder will munch casting marks quickly
