DIY afr meter
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    DIY afr meter
    Anyone done this??? any good links or know how???
    Would really like to make my own and, fit it where i like.
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
  • johne
    • Apr 2007
    • 1405
    afr???
    • Flat on my back
      • Jan 2007
      • 2449
      pay attention boys and girls...
      A is for air,
      F is for fuel,
      and R is for ratio.
      Ok...repeat after me...
      Carlos.
      • Flat on my back
        • Jan 2007
        • 2449
        Cant be arjed to do that 'here' thingy...must learn it though...
        Carlos.
        • urquattro-island
          • Mar 2006
          • 1915
          Originally posted by Flat on my back
          A is for air,
          F is for fuel,
          and R is for ratio.
          A is for air
          F is for fuel......
          • johne
            • Apr 2007
            • 1405
            OK so now I know what you're talking about. You mean a special voltmeter to measure the output from the lamda probe calibrated to read out the instantaneous air/fuel ratio.
            I have one still in it's box, never fitted so don't know how well it works or how useful it could be.
            • Matt_D
              • Dec 2004
              • 515
              They are very useful, i had a AEM Uego AFR fitted to my civic type-r, it had an ouptut that links with the ecu so when your mapping you AFR can be read also
              As for making one i'm not sure how you would do that, you need a wideband lambda probe for a start
              '95 ABY Avant - Sold
              '98 B5 S4 -MRC400+ = 464ps 741nm
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                how does that afr thingy work on the above link? Where is it connected to?No wideband lamda?Is it connected to the OEM lamda? I dont understand how it is hooked up.Do you think it is worthwhile item to use?
                • EspenW
                  • Apr 2007
                  • 1534
                  • Country: Norway
                  Output of the narrowband OXS (lambda sensor) can be displayed with a 0-1v voltmeter (high impedance).
                  However, why bother with that when wideband kits have become so cheap. The narrowband will really only tell you if you are richer or leaner than stoich (14.7:1).
                  Innovate LC-1 is thye most accurate on the market and only costs $199 (and often cheaper off approved Ebay dealers). The output of the LC-1 can be displayed with a small and inexpensive panel voltmeter.
                  1994 80E Avant
                  1986 2L Golf 2 on Alcohol
                  • urquattro-island
                    • Mar 2006
                    • 1915
                    how much is that then??
                    • urquattro-island
                      • Mar 2006
                      • 1915
                      hei espen
                      i have this but think the box is to big to, be driving around with all the time..
                      • EspenW
                        • Apr 2007
                        • 1534
                        • Country: Norway
                        I guess that you have the LM-1
                        The LC-1 is another story...
                        1994 80E Avant
                        • urquattro-island
                          • Mar 2006
                          • 1915
                          aah
                          right you are there fella.. he he
                          • johne
                            • Apr 2007
                            • 1405
                            See this: http://www.glowshiftdirect.com/white...tio-gauge.aspx
                            • urquattro-island
                              • Mar 2006
                              • 1915
                              holy skitur
                              thats a good find there johne. Thanks..
