Stripped the rear end of the CQ to fit my refreshed rear subframe and Torsen diff.
Fuel lines needed replacing, as did the handbrake cables, and by the time i'd got that far i decided i was going to go the whole hog and strip and reseal the whole uderbody with POR15 and new underseal.
Pulled off the passenger side arch liner and found some nasty rust - two patches which have rusted right through
I put my finger through a patch on the front side of the arch, and met the insulation on the other side. Then did the same on the rear side where the bumper bracket and liner screws in. This is one of those times you wish you'd never looked!
Not removed the drivers side liner yet, but fearing the worst.
At least i caught it now and not in a few years when i might need to replace the whole tubs i suppose.
Would love some advice about the best way to sort this and anyone who can help or point me in the direction of someone to talk to.
I guess its a case of cutting the rust out and welding in new plate? What is the technique for this? Any UR boys got any experience i wonder?
Cheers guys
Alex
Cheers guys
Alex
I can only assume it has had body repairs, I have never seen or heard of rust like that on these galvanised bodies. (anyone else?)
Dodgy body work? I have had my CQ since 90 and have checked the wheel arches several times through it's life. They look as clean as the day the car was built. Still has the body wax intact inside there too.
