Need help from excel experts
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    we have been trying to make an excel usable enough to produce hp+Nm figures from raw data from the perfomance box (speed vs time) however it seems that the high accuracy of the thing makes the data unsuable.
    I enclose the excel file with one of my most recent runs,in which you can see that the power figures and torgue figures are all over the place.Surelly there could be a way to make it work...i just don know much about excel so..
    here you go!If you drag the columns down you can have more figures of each column.
    the idea was that i can take the time vs speed from the PB and paste it on the first 2 columns,and then all the columns would get the data.However as the PB has a speed value every 0.1sec you end up with so many figures and so many data there.
    I have tried to pick values from the PB data,but although the graphs make more sense they are not at all near the power/torgue figures you actually have.It depends on your choise of figures you use really.
    Any help is appreciated!
    thanks
    vasilis
    I am good with Excel, but a bit lost in all this data... Andy Casey must have similar spreadsheets that he crunches from his GPS based device - which I also believe provides updates on 0.1second basis.
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      where is ANdy!!!!!
      i thought that the N95 software or GPS system on navi systems were not as accurate as this one,but if there is a spreadsheet i can test with my raw data then please let me see!!!
      cheers
      vasilis
