just took delivery of 2 new lambda's for my 2.8 80. They are the type without plugs so you splice them into your existing wiring. Not a problem I thought, read through the instructions, says there are 3 wires, fine so far, the wires are heater, signal and ground, fair enough I thought, then it says ther colour combinations are white, black and grey (on the new sensor), but when I look at the sensor there are 2 white and a black This is the same on the loom on the car. Question is what the heck way round do you connect these white wire and secondly, does it matter?
Other point is that the car has had 2 replacements already as the wires are spliced, this makes me think:
A, they may not be the fault to begin with.
B, have they maybe been wired wrong in the first place?
