mystery non runner?!
  • blues n 2s
    • Jun 2008
    • 136
    Need your help guys - recently removed head and replaced new head gasket etc - put it all back together however have one plug and dont know where it goes - its a 2 pin plug with 2 wires, one brown/blue stripe and other brown/white stripe and situated somewhere near to battery.
    Also engine won't start - any suggestions? - is getting fuel and sparking.
    Just seems to lack that last ooomph!
    I must have an S2!!!!
    Originally posted by blues n 2s
    ... put it all back together however have one plug and dont know where it goes - its a 2 pin plug with 2 wires, one brown/blue stripe and other brown/white stripe and situated somewhere near to battery.
    Because of the brown (with stripe), I am guessing they are a switched ground wire, perhaps related to a sensor, e.g. intake air temp sensor, or maybe idle stabilization valve. (I just checked my AAN wiring diagram and the intake air temp sensor on it is connected to the ECU via a Brown with blue stripe wire so that is a good clue for you).
    If noboby gives you the right anwer, you will need to search through the S2 current flow diagrams under the Technical, Electrical section of Paul Nugent's website:
    • blues n 2s
      • Jun 2008
      • 136
      http://s2central.net/main_frame.html
      thanks for your suggestion mate but it not the idle stabilisation valve and the plug is identical to injector plug.cant read diagrams(have tried for 6hrs)amgoing insane
        What about the intake air temp sensor? That's the one with the correct colour wire. Not that the intake air temp and idle stabilization plugs are identical and have been known to be swapped by mistake.
        • terrybullwon
          • Mar 2006
          • 8782
          To the hall sender on the dizzy?
          Chef
          • blues n 2s
            • Jun 2008
            • 136
            picture clues ?
              "http://C:\Users\cpw\Pictures\2009-03-15" doesn't cut it for your photos. We can't access your hard drive. Upload them to the forum, here.
              • blues n 2s
                • Jun 2008
                • 136
                thanks for help mate had to get someone else to do that.totally computer caveman so sorry no picswill seek help asap as the box of matches are calling me
