G60 slider boots
  • Acidburn
    • 13459
    G60 slider boots
    Anyone know where is best to get these from so I can refurbish some g60's?
    The piston one's are ok so I would not need a full kit just the slider one's.
  • saltinot
    • May 2004
    • 1946
    The dealer is the only place that I've found the rebuild kit.
    441 698 470
    Comes with two boots, some grease, and two bolts w/thread locker already in place.
    • Rusty
      • 18953
      Seconded, I got the kit for the rear, job done
        Agree with above... Just remember you cant get the sliding bracket pins on their own (come with new caliper only which is a bit annoying) so just clean up any rust and crud off the originals. Also - don't wazz too much grease on the pins or it just blurts out when you squeeze on the boot.
        • Nuvo
          • Nov 2003
          • 3825
          The guide pins come with the carrier not the caliper.
            Sorry - thats right of course.
            • Rusty
              • 18953
              Make sure that the pins move freely once greased, they can lock a bit so worth spending 10s wanging them back and forth to remove the excess grease.
                Lucas do a rebuild kit
                UK specialist supplier of car brake discs, pads, calipers & HEL braided hoses. Quality OE brake parts from top brands like Mintex & Brembo.
                when I did mine I polished the guide pins
                • stiglet
                  • Aug 2007
                  • 1264
                  Big Red Brakes do pretty good quality stuff too. Clicky clicky
                  He doesn't list everything on his website but give him a ring.
