Avant issues
  • Christophski
    • 3632
    Avant issues
    Last night I was looking at my fusebox and 4 fuses had all the plastic melted! They are for the front lights and fog lights! Bit scary. All changed now, any suggestions for this happening? This morning I got in my car to find a fresh leak drivers side where the headliner meets the pillar cover down the side of the windscreen (it's an avant) not happy. Sunroof drain didn't have a puddle at the top either.
  • irishs2
    • Apr 2009
    • 2455
    Corrosion on the fuse contacts could raise the resistance and cause heat, while the fuses wouldnt blow the heat could still be enough to melt the plastics.
    Could happen again, or worse some dried leaves could be set alight by the heat.
    Eric
    95 S2 Avant under rebuild.
    • mcandmar
      • Apr 2004
      • 5118
      Check you have standard 55w bulbs, if somebody put in 80w or 100w versions it will melt your fusebox.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
