S2 Avant into saloon
I've sourced Audi 90 20v 7A driveshafts, diff, gearbox, propshaft & s2 coupe hubs.....I think that should all I needLeave a comment:
You need to check the inner CV bolt PCD.
IIRC the 10v and 16v are only 90mm whereas the V6 & 20v quattro is 100mm and the S2 is 108mm.Leave a comment:
I know this is an old thread but there seems to be lots of knowledge here so......
I'm planning an S2 hub conversion on my Audi 80 (B3) quattro 2.0 16v and found a donor car locally (for free) with 82mm driveshafts which I understand fit directly onto S2 hubs.
My question is;Does anyone know if the driveshafts from an Audi 80 (B4) quattro 2.8 V6 fit directly onto an Audi 80 (B3) quattro 2.0 16v?
Thanks,
LeighLeave a comment:
You need this, and its free. http://www.s2forum.com/forum/showthread.php?t=42370hi woundering if any one could help got a s2 avant fire damaged not repairable an a 1996 avant 1.6 no its a hell ov a lot ov work but could i swap the lot over ie engine , suspention , running gear plus could some 1 post a pic ov s2 avant brakes these ones look massive just want to no if there standared any help plsLeave a comment:
your 1.6 avant will be fwd so the rear end would need cutting out and swapping over and the transmission tunnel as well iirc.Leave a comment:
Will,
I have v8 torsen rear diff ,rs4 6 speed with oil cooler,solid subframe bushes all round to do this week. Then the engine to put in on the weekend so should be done next week.
Dont know whether to put a cage in of a rs2 trim?????????? more pics next week when i do the work
Any update / photos? Nice work from what you've posted so far.
Kind regards.Leave a comment:
Dont know whether to put a cage in of a rs2 trim?????????? more pics next week when i do the workLeave a comment:
That looks spot on will. thanks for sharing the pics. look forward to seeing it finished. how much is left to go?Leave a comment:
Yup and thankyou for your help with my mums car
it was a loose connection behind the relay.
Dest I posted up some early pictures from when I went up, looks like its going to be a good one once finished. Look forward to seeing this at shows etc.
