Vag-Com problem
  • teknobod
    • Nov 2007
    • 177
    Vag-Com problem
    I have just installed the latest version of Vagcom/VCDS on my laptop (908) and when running the application for the first time it updated the cable firmware to version 1.81 (previously 1.44).
    I am now only able to view measuring blocks in the general engine data groups 001-009 on my RS2, after that the fields displayed do not change.
    Has anyone else come across this problem?
    The cable is a genuine Vag-Com HEX-COM interface.
    PLEASE HELP!!!!
    Is there any way to restore firmware version 1.44?
    Andy
    Vag-com have locked down the cable to the officially supported blocks which are 1-9 on the ABY / ADU
    Not really a problem
    • teknobod
      • Nov 2007
      • 177
      Unless you want to measure block 115!!
      Can this be fixed by restoring the firmware and using an older version of Vag-Com?
      It was working fine until the newly installed version stuffed up the firmware.
      Andy
        You can't downgrade firmware on a cable once it's been upgraded according to various www websites
        • teknobod
          • Nov 2007
          • 177
          Cheers Jamo.
          I've emailed Ross-Tech in the hope I may get some help from them.
          I'll wait and see.
          Andy
          • teknobod
            • Nov 2007
            • 177
            I've had another Vag-Com plugged in today and it behaves identically, so I presume the controller in the RS2 (and S2 variants) must be too old to display these values.
            Andy
              What as per post 2?
              • teknobod
                • Nov 2007
                • 177
                You were on the right track!
                • EspenW
                  • Apr 2007
                  • 1534
                  • Country: Norway
                  We can log some very useful things (timing, IAT, rpm, etc), but nothing compared to what can be logged on the newer Audis:
                  boost, EGT, AFR, etc.
                  1994 80E Avant
                  1986 2L Golf 2 on Alcohol
