Hi guys,
I am trying to source aftermarket cam wheels to close down some of the valve overlap of a Honda CBR600RR.
The engine isn't in a bike, but a 250kg single seater, which breathes through a 20mm diameter orifice (upstream of the TB). Hence we need to get all the air we can into the little 4cylinder!
Any help would be much appreciated,
Phil
Phil
There wouldn't be that much to design and machine if you where make yourself, or as said how about a tooth of adjustment? if theres 40 teeth lets say that makes each one 9 degrees which would a nice amount to adjust each time see if any gains were to be had. Also are you certain the pulleys aren't on tapers as standard?
