There are still people climbing the walls of these it seems. I want to make a batch up as my friend said he would make a jig up from a standard pipe.
If there is enough interest they will be made by the end of January 2010.
I can see there is many options with these as people have different set ups.
My idea is to build a down pipe that is:
True 3" using a 2.5 cone to 3" at the turbo exit
waste gate built into the down pipe as per OEM
Flexi section at the bottom of the pipe after last bend
V-Band to 3" de-catted Y section then back to stock system
The pipes will be made with or with out the De cat option. So after the down pipe it can go back to stock if you wish.
Price is dependent on the amount that i make. And with or with out the de cat.
The highest grade parts will be made to make these.
Ball Park price will be £190 - £240 for the down pipe and then up to £300 with the decat
Please let me know your thoughts and interest so i can decided if its worth wild.
Cheers James
Cheers James
Its atually comming through you but you dont know it yet
