Has anyone the picture of the top of a 6 Speed showing the 'cage' and gear linkage attached ?
CGR Gearbox
Cgr
Thanks Terry, have you any other photos as I need to see how the linkage attaches to the gearbox and the 'cage'.
The reason I ask this is that the gearbox is in my car without the cage on and I need to see whether I can fit everything without removing it.
ThanksComment
i will look tomorrow for you as i have some work to do under mine. I would say you might have to lower the sub frame to get it on. Then you may have to cut a alen key to tighten the 8mm bolts on top. Its pretty tight in there!ChefComment
