What kind of headlight?
  • varia
    • 821
    • Current: United States
    Can you guys help, what kind of headlight is this ?
    Number on it:
    VALEO
    067504
    HCR E2
    273 12.5
    It was on my CQ, with B3 hood. When i put the B4 hood up, it didnt fit
    Thank you!
    Chris
  • Acidburn
    • 13459
    They are b3 headlights, reason they don't fit the b4 is they are slightly wider, they can be used but if you slam the bonnet to hard you will shatter the glass. Ideally you need either b4 one piece headlights or ellipsoids.
    One other thing to note, if you swap to b4 headlights you need to rob the plugs off the wiring that plug in and splice it into your wiring as the plugs are different, any b4 car (1.6/1.9/2litre etc) can supply these and readily available in most breakers yards.
    • varia
      • 821
      Thank you very much!
