S2 Driveshaft Measurements
  • PeterFin
    • Oct 2009
    • 34
    I have a car in bits and various driveshafts which all are 'said' to be from an S2.
    I have measured each driveshaft but don't know which ones to fit !
    1 at 565 mm
    1 at 575
    1 at 580
    1 at 590
    1 at 600
    measuring from the gearbox to the outside of the hub I have front 634 and 640 less the amount the shaft is back from the outside of the hub (64) gives 570 and 576.
    measuring the diff to the hub gives 610 and 604 less the amount the shaft is inside the hub (64) gives 546 and 541
    I am now totally confused !!
    Has anyone got the measurements of what each driveshaft should be at each quarter ?
    PETER
  • JTK
    • Aug 2007
    • 143
    can't comment on the length really but for the front - right driveshaft should be shorter than left; same for the rear if i remember it correctly
