a4 s steering wheel on CQ
  • varia
    • 821
    • Current: United States
    Is it possible to install this steering wheel on CQ?
    Thank you.
  • Ruffiano
    • Sep 2007
    • 1458
    Early (pre 98 I believe)a4 s wheels yes, iyou need a new trim surround piece from either a euro car or from a late build 95 90.
    I have one in my garage waiting to go on.
    • Josh-stateside
      • 741
      you also need the steering column. The aluminum is larger on it on the later cars.
      • LVrainman
        • Nov 2007
        • 136
        • Country: Latvia
        if you mean exact the weel in picture then no. I tried one similar on may S2 Avant a month ago.. the end of S2 steering column where you put on the wheel is smaller (narrower) than needed.
        audiScars
        • Wolfgang
          • Mar 2006
          • 250
          hey guys,
          why not, these steering wheels had been mounted in some convertibles in the later years.
          check out the picture:
          in my opinion it´s exactly the same steering wheel...
          S2 Coupe ABY
          S2 Sedan
          S6 20V Avant
          www.audis2.de
          • Josh-stateside
            • 741
            It's not the steering wheel it's the steering column that's the problem. The turn signal stalk from the later cars doesn't fit on the early steering column. I'm picking up another steering wheel from a 2001+ audi A4 this weekend most likely. It looks different than the one I have that works with my 95 sedan. I have a complete early column and stalks, and i'll try it on it.
            • Ruffiano
              • Sep 2007
              • 1458
              Your 01 wheel has a completely different spline size
              • Josh-stateside
                • 741
                I guess it's it's a good thing then that it's still at the junkyard and I haven't got it yet. I've got the proper one allready. But I was going to sell the 01 unit.
                • Ruffiano
                  • Sep 2007
                  • 1458
                  H
                  Those are the basic steering wheels for the coupes/90s
                  • Ruffiano
                    • Sep 2007
                    • 1458
                    Here is the close up on the three spoke a4 wheel, notice the detail on the airbag,
                    • Josh-stateside
                      • 741
                      yah I have the farthest to the right setup on my late model 1995 setup. I was curious if the 2001 would work with the early setup because it doesn't have the funky design the 1995 model has but hearing the splines are different explains things now.
                      • varia
                        • 821
                        thx guys, but i still dont get it...
                        So, what do i need to put this steering wheel on a 1990 CQ?
