Seeking 4x4 help please???
  • anthonys2
    • 3512
    Guys
    I am desperately seeking advice on my range rover p38 98 4.6l model heres what i know of so far:
    getting above 2000 rpm engine starts to struggle and when driving along at 50 ish it sounds like a steam train.
    it massively overheated today loosing lots of coolant and i had to fill up from a frozen stream!!!
    my guess is its the head gasket but its not getting to the oil
    does any1 on here know of any good specialists please any help would be most grateful
    Anthony
  • BRY
    • 3755
    Tonks 4X4 on here
    • PeteRR
      • 1326
      Hopefully it's not the old slipped cylinder liner issue (4.6's have a history of it, mainly due to the fuel maps apparently).
      V8 specialists include J.E. Engineering, V8 Developments and RPI Engineering
      Have a look on RangeRovers.net for common issues/symptoms too. Although it's an American site there is lots of useful info on there;
      We’re a community forum to discuss and assist on issues with every Range Rover model. Sign up if you have a question, answer or to meet like minded individuals
      • Tonks4x4
        • Nov 2005
        • 3062
        Hi mate give me a call tomorrow on 01623 452885 i can talk you through a few checks.
        Audi Nut!!!
        • Jonnybravo
          • Aug 2008
          • 2051
          Done a few water pumps on these when converting them to LPG, also known a fair few to do head gaskets.
          • GazzaG60
            • 4133
            my mate has fitted a few engines to cars that have had lpg. dont seem to get on well RR and lpg
            • bikerjim
              • Feb 2008
              • 1028
              These cars have issues with pourous liners in the block. My dad is a landrover specialist and i have helped him replace a few engines on these. His own 4.0l did it so he replaced it with a 4.6. The replacements he uses are always either new or recon, normally a £3000-£4000 job i think.
              • Ducky
                • May 2006
                • 636
                If it has a slipped liner or porous cylinder the aftermarket top hat liner can fix it, albeit means an engine strip down. The old RV8's were known for problems over 4ltr.
                • Jonnybravo
                  • Aug 2008
                  • 2051
                  To be fair there great on LPG when all the igntion system is perfect otherwise like anything they are awful.
                  I've convered atleast 30 on multipoint Prins and BRC systems and the only issues we have had turned out to be ignition related, (coilpacks on later ones, dizzy and coil on earlier models back in the day)
                  The engine seems to work well on LPG but some of the cars were just poorly maintained which ends up showing up when the conversion was carried out.
                  The latest supercharged RR was a complete ball ache to convert but great when done, wouldn't mind one of those myself although they would make any S2 look cheap to run lol
                  • TDi90
                    • Nov 2009
                    • 272
                    There you go!
                    ask tonks! im not too familiar with P38's but give me a 200 or 300tdi and i can answer most things!
                    mine is broken lots of the time
                    • anthonys2
                      • 3512
                      Cheers guys am going to give tonks a ring tomorrow its a proper pain in the asre!! just spent £1750 on it and now this just what i didnt need!!
