QR Sport remaps
  • Jonnybravo
    • Aug 2008
    • 2051
    QR Sport remaps
    Does anyone have a S2 with one of their maps ?
    It would seem their a very reputable company but no info on their website about the specs of their chips they fit to the ABY's
    Any info would be good please
  • Puglife
    • Jun 2006
    • 731
    They were very good but Tim (Renn-tech) moved and setup his own company. I found tim was the only reason i used QRSport. No experience since 2007 so cant comment if they have improved since his departure. Give Tim a call first though.
    Jay - pug_life85@hotmail.com
    1986 Audi UR quattro - WORK IN PROGRESS
    1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
    • Jonnybravo
      • Aug 2008
      • 2051
      It was supplied before 2007 so that is atleast a good thing, I will contact him though as he can probably answer the questions I have.
      Cheers !
      • merlin's S4
        • Jan 2005
        • 1539
        Don't do it. Lots of problems with the chips that they used to use. I have a set and they were quickly replaced with an MRC remap!
        • andyg plym
          • Nov 2006
          • 4646
          i had digi-tec chips from qr in my old s2 avant, went like fek,faster than homefry imho but ran lean. fuel consumption was way too good
          • Big Lee M
            • 2571
            Was that your green avant,Andy? If so I had that ECU in my car too, went like foook. Ask GT500 I think he has a set in his UR with ABY.
            Just some finishing touches to do now
            • GT500
              • Jun 2006
              • 2181
              Yes, still in and it does 28mpg towing a car trailer with car on at 80mph! (before I got older and wiser!)
              Yes they do run lean, but so do most race cars!
              Rob..
              87 UR 20v ABY
              97 S6 Avant
              • GazzaG60
                • 4133
                running lean is not an issue. running too lean is.
                its about temps really.
                a leaner map will make more power than a richer one.
                thing with race cars is they usually use different fuel and have racing drivers and teams to support them.
                never trust a chip that's not graphed.
                • Jonnybravo
                  • Aug 2008
                  • 2051
                  ^ Good info.
                  TBH You could always fit a adjustable fpr to richen it up a bit if it was dangerously lean but I don't believe they would map it that close to the edge anyway.
                  • andyg plym
                    • Nov 2006
                    • 4646
                    thats the one Lee, yes was quite impressive, torque central:mischeif:
                    • GazzaG60
                      • 4133
                      problem with adjustable FPR is getting the rising rate to match the map. near on impossible.
                      it would end up pig rich low down and normal up top. kinda like k-jet tuning.
                      • Jonnybravo
                        • Aug 2008
                        • 2051
                        Have you excuse my ignorance on this one but would it really be that much of a problem ?
                        The vauxhall lads end up having to do it quite simply as the 4.5bar reg supplied with most kit can vary from 4 bar to nearly 5 so they choose to use a adjustable one to get it spot on.
                          Devil spawn those things on a turbo car, work well on NA, get a proper map
                          • Jonnybravo
                            • Aug 2008
                            • 2051
                            Thats totally lost me, obviously I appreciate that a map based around the set fuel pressure is perfect but I can't see why using a adjustable fpr is that much of a issue.
                            Having not owned anything like that myself I can only use a friends car as a reference but his has been fine like that for many years
                              It has to be setup correctly to use, you need to get the rising rate correct or else you afr will look good in one place and then crap the next. They are typically used to en-richen mixtures rather than lean them out.
                              If your talking about a static fpr where you can go from 4 bar to say 3.5 and it's static then yes you could use it but if you lean it out lower down your leaning it out at top and that's not good.
                              I only see them used on big injectors to get a good idle by lowering the base pressure.
                              It's a band aid fix, really you want to remap or get a good map.
