Houston we have a problem!!!
  • mallster
    • Jan 2010
    • 81
    Just replaced coil packs on the ABY, it ran lovely for about an hour and started miss firing again on no 5 all the modules are fine and there is power at the coil pack
    i will try and re-solder the wiring again just to make sure, has anyone got any idea or am i doing something wrong?
    Thanks in advance
  • Evilgoat76
    • Feb 2010
    • 278
    • Home: Canada Current: United Kingdom
    swap the output stages over and see if the misfire moves.If it does you have a failing module. You can bodge it as there is a spare channel (2x 3 channel modules are used)
    • mallster
      • Jan 2010
      • 81
      SORTED Found a chaffed wire arcing of the cover !! was'nt even the coil pack! never mind we live we learn
