anyone have any guesses what car this is (classic audi fans will most likely already know)
i'll post the link up in a bit just want to see what responses people have.
No, not 2k hp.
The engine can produce well over 2000hp,(it wll give about 2300hp at 2.4bar boost) but turbos is its only limitation , they can produce 1750hp at the maximum in teory , so we'll se how well they hang in there.
It even passes 1000hp before 1 bar(14.7psi) of boost.
If we get 1500,1700 or 2000hp really doesent matter, it is only in it's drag-spec configuration it will be ble to put down these hp numbers.
As it is now it produces 170hp at idle, 290hp at 2000rpm... and after that the turbos really kick in... so there is always enough power...!
Totally off bost, it produces somwhere between 550-600hp if everything continues as planned..
uhmm...
