Thread type/size on water manifold
  • Azman
    • Sep 2005
    • 3205
    Hi guys,
    What is the thread size for the banjo bolt on the water manifold (ABY) going to try to find a better replacement for it as mine is leaking a little.
    Also getting it cleaned and powder coated would not cause a problem would it? Looking at getting a few bits clean and tidied up when the head is off for investigation..
    Az
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • Azman
    • Sep 2005
    • 3205
    ooo also price for the two temp sensors??
    Az
    Dark Grey Avant
    RS2 FARB
    • Rusty
      • 18953
      Re poweder coating, not an issue as long as all mating faces are clear. Might as well just celan it up yourself and put a can of paint over it, you can't really see it enough to warrant any £ on it IMO.
      • Azman
        • Sep 2005
        • 3205
        Won't be £ really as having a load of other bits doen too so will just be a job lot
        Dark Grey Avant
        RS2 FARB
        • Acidburn
          • 13459
          Just don't do a madwolf and snap the studs off removing it.
          • Azman
            • Sep 2005
            • 3205
            Aha got a spare one so going to get that done then carefully remove the one attatched with a little heat to help hings along. Ooo where to get new bolts for it from..
            Dark Grey Avant
            RS2 FARB
