spherical bearing and aluminum
  • terrybullwon
    • Mar 2006
    • 8782
    Guys I am looking for a spherical bearing and aluminum weld on boss, I have looked through google and only found bits and bobs. It must be larger than M10 that's about the only stipulation.
    Thanks in advance
    Chef
    Chef
    What for James? Could you have something made?
    • AndyP
      • 6049
      I was searching for spherical bearings last night, try here:-
      Timken Aurora Bearings rod ends and spherical bearings deliver precision, long life, and dependable performance for industrial and aerospace
      Give us a bit more of a clue on the weld on boss.
      • terrybullwon
        • Mar 2006
        • 8782
        Off the shelf would be alittle cheaper, but alot of the bearings are Made with a resesse in so that a circlip can be fitted or even tappered for press fit. I don't really want to have to ask for favours with a weld on boss I can be done Monday
        Chef
          I got mine from autosport bearings
          • twoqu
            • Sep 2003
            • 3103
            What about here:
            • terrybullwon
              • Mar 2006
              • 8782
              Cheers Guys still can not seem to find any sources
              This a SS version
              Chef
              • gnutz2
                • Aug 2006
                • 928
                James are you thinking of making a short Shifter.
                I made a short shifter with a spherical bearing from Mcgill motorsport parts. I used a 5/8 sherical bearing with a steel housing with the high misalignment bushes like the ones in your pic.
                I welded the steel housing to the base plate of the original 6 speed shifter.
                Now i need to work out how to make a gate for reverse.
                I'll get some pics or have i jumped the gun a bit
                The ONLY S2 Golf!
                http://www.s2forum.com/forum/showthread.php?t=19402
                10.42@138mph
                https://m.youtube.com/watch?v=0wnkkOfFpXg
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Yeah thats right, something not plastic.
                  would love to see what you came up with, i am also making a new linkage at the gear box end
                  Chef
                  • gnutz2
                    • Aug 2006
                    • 928
                    I put multiple circlips above and below the bearing so the throw is adjustable but because i made the lever so long it's in the position for maximum throw. I wanted the gaer knob nearer the steering wheel
                    This is just my first attempt so i didnt fully weld the bearing housing on the base plate.
                    TBH the parts from mcgill motorsport were very low quality, there's no way i'd want that stuff anywhere near my wishbones they are just cheap chinese bearings probably good enough for a shifter though.
                    The ONLY S2 Golf!
                    10.42@138mph
                    • Acidburn
                      • 13459
                      Very nice
                      • G60Rallye
                        • Dec 2006
                        • 1321
                        James where abouts did you see that set up in the picture you posted?
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Hamish,
                          $129.00
                          Chef
