Holset turbo
  • Acidburn
    • 13459
    Holset turbo
    Anyone have any info/know anything about this/these.
    I got given one today
    lol and before anyone says they are rubbish I dunno, I got given it so just curious if its any good.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    i cannot make what type it is. Holsets are efficient and have 360deg journal bearings. Very nice wheel design as well. I wouldnt use a bigger than HX35 on our engines though for a daily driver.
    i tried HXsuper40 which is as big as a GT35 and its way too laggy
    • Sleeper_Avant
      • 2372
      Looks like a H25 from what i can make out from the numbers, most probebly off a diesel motor..... cummins probebly!
      looking at how bad the compressor housing is, hope your not just bolting it on!
      if it is off a diesel it will be no good on your motor, have a look inside the exhaust housing, if the black soot is loose inside its a diesel and the exhaust housing is probebly huge with a small in comparison compressor........
      1993 URS4 Avant Emerald Green 350+bhp
      1991 Ford Sierra Sapphire 4x4 in Magenta
      BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
      • quattro84
        • Mar 2006
        • 947
        Ancient baby! From the identifier i can see that it came from a British Leyland Olympian or Titan.
        Because it is an older frame spare parts are a bit harder to find and normally a tad more expensive.
        If you want to take it apart/rebuild here is a manual: http://issuu.com/dieselusa/docs/hols...owFlipBtn=true
        Service kit nr: 3545653
        I can't find any partnr's for the wheels, so i don't dare to say how much it'll flow.
        • Acidburn
          • 13459
          Sounds about right and it came with a car shell that I picked up, I was just curious about it and yeah it is a bit huge
          • Acidburn
            • 13459
            Thanks for the replys, lol sounds like a nice paperweight or pen holder, might polish it up and stick it on the bay, some ricer will have it.
            • Sleeper_Avant
              • 2372
              LOL class! bet it does 500sovs!
              i made the same mistake with a supposed RS200 turbo on a big power cossie project once, sent it to turbo technics for a refurb and it turned out to be leyland bison, 1980`s truck!
              still the car did 486bhp with it though.
              cost me £800ish to get it refurb`d, wasnt impressed as they told me after they did all the work
              • Acidburn
                • 13459
                Sounds about right for them I used to have a turbo technics converted sierra cosworth rep, that was not bad 300ish brake on a saab turbo.
                • quattro84
                  • Mar 2006
                  • 947
                  Without the right hotsides the Holsets are rubbish. In order to run it you have to machine a Garrett/KKK/BorgWarner/Mitsubishi one or find a aftermarket version like Bullseye power does.
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    yes indeed. That way you may end up with a solution that is good enough for our engines and not be too restrictive at the top end as well.
                    • GazzaG60
                      • 4133
                      or just use it as a boat anchor and buy a proper turbo.
