Another one for the curious minds out there. This is the old style unit with a round outer casing from a 1991 7A car. I finally got around to replacing this unit as it went faulty, whenever the engine had fully warmed up the sensor failed to register anything below 1.5bar. I just couldn't take it any longer with the autocheck beeping away while sitting in traffic.
Fairly simple device, there is a small plunger in the bottom of the unit that the oil pressure pushes against raising the platform. On the front side shown there is a resistance track for the gauge, and on the back side there is a contact for the low oil pressure warning.
The sender seem to require voltage and the pressure gauge logic to work, so with an AUX gauge cluster wired up and reading 13.5volts, the wire to the sender was giving out a little over 8 volts. Seems a bit of an odd figure to me
