Help and advise me please!
  • anthonys2
    • 3512
    Ive just been looking through my receipts for the s2 and have realised that i havent changed the timing belt since oct 2000!!! thought i had but it doesnt appear that i have!? So the belts and tensioners all need doing what else should i replace for eg the water pump/oil pump?? please advice thanks
  • add
    • Jan 2008
    • 931
    cambelt,tensioner,waterpump,crank sprocket&bolts,crank bolt.
    You will also need to get hold of a proper locking tool
    HTH
    It's a love/hate relationship with the S2,i love it,it hates me
    • GazzaG60
      • 4133
      making a locking tool is easy. get a flat piece of steel and ideally the top of a large axle stand or tube. cut about 3 inch off it. weld it to the plate, burn a hole in the back so the socket goes through. cut a small bit out to replicate the locking area on pulley. cut big hole in end of said flat piece so it hooks on the stub mount locator.
      do belts and tensioners and water pump. look at the oil pump but changing is a bigger job.
      triple double check the cam pulley isn't fractured at the key.
      • anthonys2
        • 3512
        cheers guys i guess this aint going to be a cheap service this year!! never ending expense these S2s!
        • Rikki Kitto
          • Feb 2010
          • 6276
          I did similar recently cam belt, tensioner, pulleys, v belts, water pump rocker cover gasket (don't know why mechanic took this upon himself) £420 parts and labour. Good luck.
