what kind of wire should be used?
  • ryster
    • Sep 2007
    • 224
    car has been holding back alot lately and has a slight misfire.
    i have changed ;-
    spark[plugs
    lamba
    wgfv
    coilpack boots
    also i pressure test ( i have small leak on the pcv system by the bottom of rad)
    when changing sparkplugs and boots i notice the wiring / ( plastic coating )to the coilpack s and earths seemed to be cracking from the heat. i was thinking this is maybe why cause of the misfire .
    To keep the cost down to start with i was going to replace the wiring to the coilpack etc. is this possable ? and if so what kind of wire should be used ( something that withstand the heat ) as the normal wire i use would surely melt ?
    any would be much apprecated cheers
