How to.... Aux Gauges
  • Christophski
    • 3632
    Hi Guys
    Anyone know how to remove the Aux gauges? Ie the small ones for Oil pressure, battery and Oil temp?
    Please dont say its a whole dash out job.
    Chris
  • Fat Audi 80
    • 10547
    Do a search, this has been covered numerous times.
    Basically, you need to remove the trim around the handbrake cover, prise of the square screw cover in front of the button on the hand brake and also under the rear ashtray to release the handbrake cover, you can then work on withdrawing the centre console towards the rear of the car...
    HTH
    The Perfectionist
    • Christophski
      • 3632
      Cool cheers. I have just found a thread. Do I need to take the whole hand brake cover bit out and then the panel above for the heater controls just to get at the Aux Gauges?
      Seems alot just to get at them when they are on a different panel of dash.
      • Dan
        • Jun 2008
        • 1242
        Grab the doc for the aux gauges and follow it up to removing the cluster.
        Just yank out the 3 heater knobs, pull off that panel, take the rear ashtray out... deal with the handbrake cover - you don't need to take it off, just slide it back, whip gear stick cover off and Bob's yer uncle.
        1993 ABY Coupe | BMW R1200 GS
        A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
        • Christophski
          • 3632
          Cheers Dan
          That is better than the other guide I found to do it!!!!
          • LSG
            • May 2010
            • 897
            Hi chap if you like you can pop up to wokingham and we can do it in the work shop also gives you a ramp to have a good look under the beasty.If you like pm me with some dates see if we cant sort it out
            • Christophski
              • 3632
              Hey dude Thanks for the offer. May take you up on that at some point but I think I can do this one on the drive. Especially after building my 69 beetle on the drive or in my garage. I have friends with a unit and a ramp but hopefully I wont need it for the aux gauges however if I do I have done something seriously wrong!
              May take you up on that offer at somepoint so I can do my rear diff seals as they are a tad leaky and wanna sort them out.
              You got an S2 then LSG?
              • LSG
                • May 2010
                • 897
                Hello again yes got an aby and a 23 e ten valve love them both dearly.Work with bikes at big cc, I run the workshop and everthing else Give me a shout if you need somewhere to work all the best lynn.
