Audi S2 2.0TFSI +500hp with GT3071..........
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    the car is ugly¡ ¡
    with only 2000cc and GT3071 ???
  • rs200
    • May 2009
    • 1398
    • Home: Croatia
    audi s3 with FWD...? is this something new?
    • prj
      • Mar 2010
      • 6308
      I am sure they just disabled the haldex, because they did not have a 4WD dyno.
      • Jonnybravo
        • Aug 2008
        • 2051
        Originally posted by Rocco
        http://www.youtube.com/watch?v=bbAWJ...layer_embedded
        the car is ugly¡ ¡
        500hp is possible on a 3071
        • driftin jo
          • Sep 2007
          • 2222
          560HP is possible
          • Billman
            • 4129
            I am having very hard time to believe these numbers.....it only has a 53 compressor inducer and i dont believe it can support this hp while lasting long (i am speaking about the turbo).
            It can give a max 48-50 lbs/min..... maybe they are using another chemical-fuel that releases oxygen and thus getting more from the combustion but not only from this turbo....
            Go Holset or Go RS4
            • EspenW
              • Apr 2007
              • 1534
              • Country: Norway
              Crank power claims from a rolling road must be taken with an enormous grain of salt anyway.
              1994 80E Avant
              1986 2L Golf 2 on Alcohol
              • driftin jo
                • Sep 2007
                • 2222
                Wrong ! It can flow ~ 54 lbs / min , see link to garrett .
                Garret rated from 340- 560 hp.
                • Jonnybravo
                  • Aug 2008
                  • 2051
                  Several people are now seeing 500+hp using this turbo on a 2l litre engine. I have to be honest it must be a awesome setup as its a great 400hp turbo, let alone a 500hp one !
                  • driftin jo
                    • Sep 2007
                    • 2222
                    You wouldn't be using the same comp wheel and turbine AR on a 3071 for 500 HP as the ones you would use for 400 HP, I'm guessing if you are making 500 + then more lag is going to have to be expected for the bigger exhaust AR and bigger comp wheel .
                    This little piggy make up to 460 HP
                    This little piggy make up to 560 HP
                    both little piggies are 3071
                    • Jonnybravo
                      • Aug 2008
                      • 2051
                      Agreed, however the larger 3071 still pulls better low down than a 3076 for example.
                      • Rocco
                        • Aug 2007
                        • 6393
                        • Country: Spain
                        and why are not there any S2 with GT3071 with +500hp?? with more displacement.... ?
                        • driftin jo
                          • Sep 2007
                          • 2222
                          Because most people are running the 56 trim .50 AR compressor wheel .
                          • Billman
                            • 4129
                            http://www.turbobygarrett.com/turbob...R_803712_1.htm
                            With the difference that we are talking about the GT3171R and not the GTX series that use other compressor impellers.
                            Rated by Gerret for max 480 hp!
                            No matter what combo you are using the ultimate restriction comes from the compressor inducer and the turbine exducer.
                            Classic GT3071R has a 53mm compressor inducer and it is almost impossible to brake the 500 mark with it.
                            Go Holset or Go RS4
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              and what happen with the 0.63 AR?? is it possible?? and with the 0.82AR?? +550hp??
