A4 B7 Dtc
  • bad8008
    • Jan 2010
    • 255
    • Country: Brunei
    A4 B7 Dtc
    Hi
    wonder if anyone has experience "PRNDS" blinking at the panel?
    Did a scan and these faults came up;-
    VIN: WAUZZZ8E37A101147 Mileage: 65130km/40469miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B
    Component: 1.8L R4/5VT 0010
    Coding: 0011581
    Shop #: WSC 06335 000 00000
    VCID: 7F06CA3E577B
    1 Fault Found:
    17072 - ECM Power Relay Load Circuit: (J271): Open Circuit
    P0688 - 004 - No Signal/Communication
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 8E3 910 155 T HW: 01J 927 156 HT
    Component: V30 01J 1.8l5VT RdW 0010
    Revision: 00000009 Serial number: 00000001024870
    Coding: 0000001
    VCID: 3972E42609DF
    2 Faults Found:
    005975 - Supply Voltage: Open Circuit
    P1757 - 000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 87
    Time Indication: 0
    Freeze Frame:
    RPM: 96 /min
    RPM: 0 /min
    (no units): 1.0
    Torque: -34.0 Nm
    Temperature: 31.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 0101 0 0
    049408 - No Communication with Engine Control Module (SAE:ECM/PCM)
    U0100 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 254
    Time Indication: 0
    Freeze Frame:
    RPM: 96 /min
    RPM: 0 /min
    (no units): 1.0
    Torque: 0.0 Nm
    Temperature: 31.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 0101 0 0
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004872
    VCID: 2C5CCD72F68D
    1 Fault Found:
    01314 - Engine Control Module
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 1
    Fault Frequency: 112
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4722
    Hex Value: 0x0014
    Hex Value: 0x4197
    Hex Value: 0x0000
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 901 C HW: 8E0 920 901 C
    Component: KOMBI+WFS 3 H14 0110
    Revision: 0110 Serial number: AUX6Z0F0055085
    Coding: 0004148
    Shop #: WSC 00010 777 63489
    VCID: 254A38569567
    1 Fault Found:
    004 - No Signal/Communication - Intermittent
    This happen intermittently.
    "PRNDS" blinking gone after replaced the battery 1 month a go. Now it came back.
    Help..
    2002 A3 8L
    2005 TT 3.2 Quattro
    2007 A4 Avant B7 (hers)
    2009 100 C4
    2009 A6 Avant (hers)
    2010 RS2
    2010 S2 Saloon
    2011 KTM SuperDuke 990 Olive Green
  • pazzle
    • Aug 2014
    • 1
    Hi,
    Had exactly the same problem this morning, did you manage to find the cause or resolution?
    Regards.
    • Monkeymagic
      • Mar 2012
      • 3419
      Check the fuse. I think it's number 29.
