Electrical Fault
  • benntenn67
    • Jun 2009
    • 859
    Electrical Fault
    Hi, I have a fault with my turn signals - when I indicate left or right, all (front, back & side) flash ? as if the hazard warning lights are on. Any ideas to where should I start looking ?
    Audi S2 Coupe 1995
    VW Passat GL5 (hatch) 1986
    VW Passat GL 1.8 (saloon) 1986
    Carrera Subway 8
  • epic
    • 1317
    Check for corrosion on the bulb holder plates on the back lights. Common problem on Coupe's to leak around the lights. I had to silicon seal my old coupe rear lights and change the buld holders
    • s2driveruk
      • 12696
      oh yeah what he said , i had proper disco lights on mine when the lightboards corroded and also if you use a twin filament bulb on one of the tail light's it also can cause issues.
      1992 3b S2 Coupe
      • benntenn67
        • Jun 2009
        • 859
        Checked the rear light bulb holders & they were fine, (the seals don't leak & the boot stays dry) ... checked the fuse box, that was ok & dry..... so I then checked front & side bulbholders, the seals etc & they were ok, no corrosion .... into the interior, removed the hazard warning switch, refitted it & hey presto, indicators working fine
        S2's can have stange faults sometimes ??????
        Audi S2 Coupe 1995
        Carrera Subway 8
